Starter
Old Sep 21, 2012 | 06:15 PM
RJ350's Avatar
Default Starter
Need a recommendation for a full size starter that can handle the heat from headers. I have a 72 Camaro with a slightly worked 350. Thanks
Old Sep 21, 2012 | 07:26 PM
Not sure of any that can handle too much header heat for a long time. If the headers aren't too close any stock starter will work fine for a long time. I've run a stock rebuilt starter on my 427 for 13 yrs. now with headers, and works great.
How close to the starter are your header tubes? You can install a heat shield between the headers and the starter and greatly increase the starter life. You can also get header wrap and wrap the tubes that are close if needed.
iLL95
Oct 17, 2011 02:51 AM
VanHalen
Jan 6, 2010 09:02 PM
Celticsfan
Feb 17, 2007 10:16 PM
camarodrifter
Dec 29, 2006 08:08 PM
94Z28interceptor
Nov 14, 2006 08:09 PM
