door problem
Old Feb 26, 2007 | 07:18 PM
blkmgkcamaro's Avatar
March 2007 ROTM
Default door problem
my driver door sags on my 88. how much work is it to replace the pin? i see that they're only like 5 bucks, but i heard they're tough to change.
Old Feb 26, 2007 | 10:41 PM
91camaro305rs's Avatar
Default RE: door problem
I was told that my hinges were bent and weak so they would have to be rebent andwelded. Even to replace the pin you have to remove the door to put the new washer thing in.
Old Feb 26, 2007 | 11:32 PM
MadMikeZ28's Avatar
You dont have to remove the door. It is easier tnat way. But you need to get a special kit for the upper hinge since it has permanant rivets. The lower hinge I think is the same as S10 pins and bushings.
Old Feb 26, 2007 | 11:43 PM
MadMikeZ28's Avatar
I think this is the guy who made them. I dont remember for sure because I got them for my door a couple of years ago.
http://www.andyz28.com/index.htm
Old Feb 27, 2007 | 04:51 PM
March 2007 ROTM
is this the same thing because on your site it says 100 bucks and this site has it for 10 bucks.
http://cgi.ebay.com/ebaymotors/82-92...spagenameZWDVW
Old Feb 27, 2007 | 05:39 PM
MadMikeZ28's Avatar
Blkmgk
That is just the pins for the lower hinges for both sides. You can get those at autozone or crapa. The hinge kit I showed is to repair the upper hinges permanentrivets and it includes the lower pins and bushings for 1 side. When I got mine there was no greasable ones and it was like $75-$80
Old Jul 5, 2007 | 06:52 PM
March 2007 ROTM
madmike my dad drew out this sketch and then i put it onto paint. the part that is worn is not part of either of the upper or lower hinges. it's worn on the part that is welded to the door. is there anyway to fix this other than cutting off the hinge and rewelding one on?
[IMG]local://upfiles/5168/1516D9D048B34314B2C147F26339D0EE.jpg[/IMG]
Old Jul 5, 2007 | 08:37 PM
MadMikeZ28's Avatar
Thats worn because the bushings wore out and its been riding on the pins and wearing into each other. I have had to weld on the worn sides of hinges before then round the hole out for the pins and bushings. So its either weld the worn part and get the pin repair kit or drill the hinge and the repair hinges usualy have the holes for the bolts in the same sopts as where the welds were. I have never done the whole replacment hinge on a Camaro but I do know when you buy a new door shell for the 90's full size trucks you had to buy a bolt on hinge because they are welded also and the new doors do not come with hinges. The upper bolt on hinge on every one I did needed about a 1/16 shaved off it or the door did not sit right.
Old Jul 8, 2007 | 09:42 AM
March 2007 ROTM
i temporarily fixed it. i opened the door slightly, and jacked it up beyond the normal height. i'll probably have to do it again, but for now it works.
Old Jul 8, 2007 | 08:49 PM
MadMikeZ28's Avatar
Yeah you just bent the inside of the door area to compensate. I used to have a tool that had a pin that went in the latch and on the other and of a short arm had a notch that when on the door pin then a long lever to pull or push doors to make them close easy.
91_Camaro_RS
Feb 19, 2009 07:48 PM
670eddie
Jan 25, 2008 09:40 AM
MassholeLT1
Dec 1, 2007 07:16 PM
72charger
Apr 23, 2007 09:34 PM
blkmgkcamaro
Nov 15, 2006 10:15 PM
