LOUD CLUNK NOISE COMING FROM REAR ON ACCELERATION
Old Dec 31, 2005 | 09:04 PM
91ConvertibleCamaro's Avatar
Default LOUD CLUNK NOISE COMING FROM REAR ON ACCELERATION
When I accelerate medium to hard, I get a nice loud CLUNK from the rear of my 1991 RS. I've heard it could be the panhard bar or the bushings, but what else could it be? I haven't had a chance to look under it yet, but any other possible causes would be nice to know about.
Thanks for any advice
Old Jan 1, 2006 | 12:28 AM
The_Shadow's Avatar
Default RE: LOUD CLUNK NOISE COMING FROM REAR ON ACCELERATION
I had the same thing with my IROC it was the transmision mount. It sounded as if it was coming from the rearend, but since the tranny and rearend are connected with the torque arm, the sound was transmitted to the rearend from the transmission.
Old Jan 1, 2006 | 01:26 AM
waytofast's Avatar
i had the same problem 2 and it was also the transmision mount..
Old Jan 1, 2006 | 10:41 AM
Boost's Avatar
Well, it could be Tranny mount, Universal Joints, Rear end... I dunno of anything, but those i know of.
Old Jan 1, 2006 | 02:02 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
def. sounds like a trans mount IMO
Old Jan 1, 2006 | 02:11 PM
Lee Willis's Avatar
Its very likely the transmission mount, as you can see from a concensus of the posts above, they tend to go on this model (and other Camaros) a lot at somewhere between 10 and 15 years, and they are not that expensive to replace, so I would just go ahead and do it. 90% likely to fix your problem, and if it doesn't you have fixed something almost sure to break in the next year or so and you know that's not it.
Old Jan 1, 2006 | 04:49 PM
waytofast's Avatar
u should be able 2 tell if its the transmission mount by just looking at it...if the rubber on the outside is all shreded up its prolly boke and i think it was 7 bucks for a stock one or 19 bucks for the heavy duty mount...
DDRDiesel
Mar 19, 2013 06:19 PM
kane82
Jun 7, 2012 04:21 PM
krjcook
Sep 18, 2011 12:49 AM
Godzilla179
Nov 26, 2010 02:11 PM
Cammy 3.8lV6
Jun 23, 2010 01:00 PM
