lost keys
lost keys
I have a 91 camero rs with the 305, lost the keys and now have a usless car. I was wondering if anyone here has a used camero, junker, for sale so i could replace all that PASS crap and get her going again. if someone knows a camero graveyard that would help also....
there are ways to bypass the passkey system and just use a standard key. you can bypass it yourself and have a key made by a locksmith, or swap out the ignition. im not sure how to bypass it, but the other members here can help
lol tried that and they say my camero did not come with the pass system .... got them to cut me a set of keys according to my vin,(double checked the vin five times), didnt work, door or ignition did nothing.... im at a loss, i dont know if someone already changed the ignition cylinder and ecm or what but i realy need this car running lol.
if its a 91 then your dealer is full of crap about your car not coming with vats
bypassing your vats is extremely simple, ive done it on many thirdgens, only problem being you must have or know which of the 15 resistance values your key had
if you decided to swap just the cylinder you will not need to swap ECM's, you need to swap the passkey control module which actually checks to make sure the resistance value of the chip matches what it needs to complete the circuit, ive never messed with or want to mess with the actual module
if i was you i would just bypass the vats and have a locksmith cut you keys for your locks and ignition
