Brake Bleeding
Old Aug 24, 2010 | 10:15 AM
Sante's Avatar
Default Brake Bleeding
I am trying to bleed my brakes and I had no problem bleeding the rear but after rebuilding the front calipers I can't get the fluid to come out of the bleeder values. I keep pumping the brake but the fluid is not coming out. What could be the problem?
Old Aug 24, 2010 | 10:39 AM
CamaroBeau's Avatar
could it be too much moisture in the brake system?
Old Aug 24, 2010 | 11:13 AM
Do you have someone helping you? With the bleeder closed, one person pumps the brake pedal a few times and holds it, and you open the bleeder till the pedal drops to the floor. Hold pedal down, then close the bleeder and do it over again. If you're pumping the pedal with the bleeder open, you're just sucking air right back in. If you're already doing it right, open the bleeder and try letting the fronts gravity feed, with the cover off the reservoir, until fluid starts to run out.
Old Aug 24, 2010 | 07:03 PM
microkid's Avatar
March 2011 ROTM
Technical User
another way to do is is to use some vacuum hose the same size as the bleeder and run it into a 20oz soda bottle with some brake fluid already in it. its enough to keep air from drawing back into the caliper. thats the "toyota approved" method we use at work
djsquare1
Aug 28, 2013 10:38 AM
mrfreez
Jan 2, 2012 02:45 PM
BasicConcepts
Mar 16, 2010 09:59 AM
slpcamaro
Feb 19, 2008 06:34 PM
95redrocket
Jan 5, 2007 12:33 PM
