Interchangeable 3rd Gen Parts
Old Nov 10, 2010 | 05:18 PM
Levi61092's Avatar
Default Interchangeable 3rd Gen Parts
Hey, I've got an opportunity to buy an 85 Z28. It needs a fuel pump and I have one from a 91 RS. I'm not sure if they're compatible. I think the Z is carburated. The RS is TBI. Would that matter at all when it comes to the fuel pump? Thanks. Feel free to use this thread for your own Q's and A's too.
Old Nov 10, 2010 | 09:06 PM
FSTKMARO's Avatar
I have not done that swap but I suspect the pumps are the same. Look them up for both cars at Autozone.com or advancedautparts websites. If the resulting part number is the same, voila!
I hope this helps.
Old Nov 11, 2010 | 07:49 AM
djs383's Avatar
I hope this helps.
Double check to see how the car is aspirated. If its carb, it will be a mechanical pump. If its TPI it maybe the same as TBI, I wouldn't stress over it though. Any fuel pump is rather inexpensive.
Old Nov 19, 2010 | 05:19 AM
RSSSCamaro's Avatar
Default Fuel pump
The carbureted car will have a mechanical pump; whereas the fuel injected pump will be an electrical unit, located in the tank and it runs about 30 psi. The mechanical pump runs approximately 6 psi and it is located on the lower right side front of the block.
Old Nov 19, 2010 | 04:24 PM
one92rs's Avatar
also a tbi pump is about 14 to 18 psi. a tpi pump puts out a lot more so they are not the same.
CountTripula
82-92 V8 Tech
Jul 8, 2015 11:58 PM
coronny
May 18, 2015 07:31 PM
mtn_maro
Sep 16, 2008 10:21 AM
Mraktos
Jul 12, 2008 12:42 PM
homes322
Apr 15, 2007 02:17 AM
