ignition switch problems
Old Jun 9, 2007 | 11:52 AM
mongo's Avatar
Default ignition switch problems
i have a question. i have a 1989 rs camaro and my ignition tumbler will not go any further than the on position. which lead me to believe my ignition switch is messed up and the rods are not pushing on the switch. now knowing that what is the easiest way to to fix that problem?
thank you for your help.
Old Jun 9, 2007 | 01:16 PM
MadMikeZ28's Avatar
Default RE: ignition switch problems
Replace the switch.
The start position may be worn or burned out. The switch may have moved. Can you turn the key back to its accessory position? You can lower the column by taking off the nuts and let it drop some. They you can see or feel the rod as it works.
Delray Gugle
Apr 7, 2014 07:04 PM
Saint_Ali
Nov 19, 2008 11:15 PM
1977 402
Jun 8, 2008 03:53 PM
1969396SS
Mar 24, 2008 04:34 PM
Scott
Apr 1, 2005 03:55 AM
