I need an Edelbrock Carb expert.....
Old Jun 7, 2007 | 08:49 PM
ScottD's Avatar
Default I need an Edelbrock Carb expert.....
Im running an Edelbrock 600 on my new 350. Im having two issues.
1) Vapor lock. (the fuel line is almost touching my header)...No big deal here, Ill relocate the line.
2) When I shut the car off and then try to restart it (say after getting gas) I have to hold her WIDE OPEN to get it to start again, and takes about 5 seconds of cranking. Now, this much I know....the choke is fully open. Not a choke problem. The mixture screws are opened about 3-4 turns. Im running about 8 degrees of initial timing.
You guys got any suggestions as how to fix this PITA?
Old Jun 8, 2007 | 10:23 PM
ScottD's Avatar
Default RE: I need an Edelbrock Carb expert.....
cmon, dont make me post this in the motor forum!
Old Jun 8, 2007 | 11:19 PM
Danzig's Avatar
Float level is not set correctly, these carbs are actually a Carter carb with Edelbrock on them so I am told. Notorious for floats not set correctly.
Old Jun 8, 2007 | 11:51 PM
350rs's Avatar
March 2008 ROTM
id be interested to know myself. we have an edelbrock, never had any problems with it at all, its a 600 performer series, electric choke. Biggest problem we have is decideing which springs and jets to put in. We change them a lot depending on the application, towing the boat, more power, just driving around, less power. Takes about 5 min to do the change, its very nice.
Old Jun 9, 2007 | 02:19 AM
MadMikeZ28's Avatar
ORIGINAL: Danzig
There is the edlebrock Q jet. But he most likely has the edelbrock carter built by webber USA
Old Aug 1, 2007 | 10:31 PM
rockin85's Avatar
if you want my opinion, get a holley. the edelbrock name is great but with carbs their not all that, you need to get a fuel regulator cuz the pump is too much for it, and normally all you can do on those things is adjust the idle.
ccamaro88
Jan 16, 2010 11:03 AM
maskedman
Jun 2, 2009 05:27 PM
1980_CAMARO
70-81 V8 Tech
Mar 6, 2008 10:58 PM
68ssap
67-69 V8 Tech
Aug 15, 2007 10:37 AM
69RS350
Apr 22, 2007 10:14 PM
