HOW TO: overcoming 115 mph speed limiter
Old Apr 19, 2007 | 06:36 PM
Abyliks's Avatar
Default HOW TO: overcoming 115 mph speed limiter
ok first of all, you should NOT be going this fast on public roads, i have done this for the simple fact that i put 3.73s in and never corrected the speedo so i could only do 75 mph on the highway however, for those of you who have driven I84 in CT or I495 in mass, you will die at that speed
ok first things first, dissconect the battery
next get at the computer in the passangers side foot well, there is a black pannel which has 3 screws which needs to come off, then, reach up and slide the computer down
go to the smaller connector and find wire "A10" it is a brown wire on the smaller of the two connectors to the computer
next snip the wire, this is the Vehicle speed sensor (VSS)now you might be thinking, great, no more VSS woo whoo, wrong, this can control shift points and TC lockup, also, you will receive a constant SES light if this is done, you need to wire in an on and off switch run some thiner (i used 16 guage i believe) wire and find a spot you like to put the switch in, i put mine to the left of the steering wheel right below the HVAC vent
i can wire about as good as homer simpson, so if i can do it any one should be able to
Old Apr 19, 2007 | 06:54 PM
Hisss04Cobra's Avatar
Default RE: HOW TO: overcoming 115 mph speed limiter
You have a pretty finger.
Old Apr 19, 2007 | 08:34 PM
350rs's Avatar
March 2008 ROTM
ORIGINAL: Hisss04Cobra
cause THATS not creepy... lol j/k man.
ive been thinking about doing that this weekend. how long did it take you?
Old Apr 19, 2007 | 09:14 PM
uradumass5695's Avatar
Step One: Unplug Computer
Step Two: Install Carburator
(The switch might be a little easier though)
(A little more cost-effective too...)
Old Apr 19, 2007 | 09:58 PM
350rs's Avatar
March 2008 ROTM
haha i wish i could, but that whole money thing... yea...
Old Apr 19, 2007 | 10:14 PM
I know what you mean man im in the same boat... friggin throttle bodies...
Old Apr 20, 2007 | 12:22 AM
91camaro305rs's Avatar
I might just do this to this weekend
Old Apr 20, 2007 | 12:32 AM
350rs's Avatar
March 2008 ROTM
im gona try i think
Old Apr 20, 2007 | 12:40 AM
Abyliks's Avatar
took me all of ten minutes to do, switch was a pain to mount, and the drill sliped[:@](that crack) i had already done this as the wire was cut and wire tyed but i figured id share cause i was board
can a mod sticky this or something or do they not do that here?
buddywackos
Jan 19, 2008 06:48 PM
tyler2497
Apr 7, 2007 04:28 PM
chrshadil
Apr 4, 2007 03:34 AM
chadimus06
Dec 3, 2006 01:36 AM
mean96v6
Aug 14, 2006 09:30 PM
