hood alignment?
Old Oct 14, 2008 | 12:59 AM
mtn_maro's Avatar
Default hood alignment?
how hard is it to close everyone else's hood. mine i need to push down with more force than im used to using to close a hood with. is this normal? or do i still have an alignment issue?
Old Oct 14, 2008 | 01:39 AM
MadMikeZ28's Avatar
Default RE: hood alignment?
Mine is easy. But they do have that spring which might make it seem harder than others without one. I never push on a hood to close them. They will dent. Hold it up about a foot or two and just give it a little push as its on the way down. If that does not close it make sure the latch is not having to pull it to one side. Maybe adjust it up a bit and/or move the rubber stoppers.
Old Oct 14, 2008 | 02:17 AM
mtn_maro's Avatar
sweet thanks. i need to pull it off tomorrow to paint it so when i put it back on ill try that for sure
Old Oct 15, 2008 | 04:57 PM
92 Z28's Avatar
my hood latch is busted from the inside and my hood won't open at all![&:]
Old Oct 15, 2008 | 06:07 PM
MadMikeZ28's Avatar
ORIGINAL: 92 Z28
Well you are just screwed! Hope your not close to some thing like an oil change [:-]
Old Oct 15, 2008 | 07:42 PM
mtn_maro's Avatar
oh yeah i got it aligned. but right now i have it off with the paint drying
Old Oct 16, 2008 | 12:17 AM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
Mine is very slightly bent from some idiot in a parking lot, (not even really noticeable) but it is more difficult to close it than it should be, and usually sounds like I'm slamming it shut when I do.
Although, the hood hydraulics are also a factor- it won't close all the way on just its own weight.
Ehh, whatever~
Old Oct 16, 2008 | 01:21 AM
MadMikeZ28's Avatar
ORIGINAL: mtn_maro
I just got a glance at your sig.
"chome wheels I'm not fond of....Fiberglass hood flew off..."
That is pretty specific. Might even be TMI
Old Oct 16, 2008 | 01:53 AM
mtn_maro's Avatar
lol. yeah fiberglass hood has been replaced by an iroc-z hood. the rims im trying to find a set of stock rims. then i have a friend who is going to buy the rims i have.
StoveBolts
Jul 6, 2011 01:19 PM
1989fbody
Aug 31, 2009 04:34 PM
JaySan
Oct 3, 2008 09:57 PM
hubes
Jul 24, 2008 11:18 PM
Torque Junky
Jul 30, 2006 11:40 PM
