Detailing Discuss detailing your ride within.
Hood Alignment Suggestions
Old Jun 7, 2006 | 03:14 PM
Torque Junky's Avatar
Default Hood Alignment Suggestions
My 71 has a fiberglass cowl hood and I'm having trouble getting it lined up. I have got it adjusted where the hood sits flush next to the hinges and up front by the latch. However, it is sitting up too high on both front corners, is there any way to fix this without doing major mud work? Swaping out the hinge springs for lower tension springs wouldn't do anything to help right? I am not to familiar with working on fiberglass, I am unsure if I can reshape it without damaging the paint, so I'd appreciate any help...
Old Jul 30, 2006 | 10:04 PM
Blade's Avatar
June 2007 ROTM
Default RE: Hood Alignment Suggestions
Do you have tha hood hinge springs on? IF SO TAKE THEM OFF! Fiberglass doesnt stand up to the pressure from the spring. did u adjust the hood stoppers on the rad core support?
Old Jul 30, 2006 | 10:25 PM
MadMikeZ28's Avatar
Do like Matt said and take those springs off before you break your hood in half.
Also the easy thing to do is remove the latch so the hood is not being pulled by it. The hood may be latching and the stoppers may be pushing the corners up. Make the hood so it closes good and sits fine without the latch then install the latch and make it fit that way.
Also I had a harwood on my 84 and the change in temp would make the corners move. I adusted it in the sun and it sat fine but as it cooled the corners would rise.
Old Jul 30, 2006 | 11:40 PM
Blade's Avatar
June 2007 ROTM
just some more advice put some tape on the edges of the car and hood so u dont chip the paint if the other person holding it does drop it too fast. Good call Mike about the hood latch.
StoveBolts
Jul 6, 2011 01:19 PM
1989fbody
Aug 31, 2009 04:34 PM
mtn_maro
Oct 16, 2008 01:53 AM
hubes
Jul 24, 2008 11:18 PM
sewerrat
Jan 4, 2007 08:59 AM
