Gas Leak
Old Dec 1, 2006 | 02:21 PM
amdmaster1's Avatar
Default Gas Leak
Hey does anyone else get a gas leak out of the gas cap area? It seems like everytime i go to fill up and get a full tank by the time i get home gas splashed out onto the side of my car... i have a gas cap and gas cover door and everything... i just notice that and wondered if someone else or everybody is having the same problem and what the fix for it would be.
Old Dec 1, 2006 | 02:27 PM
1983camaro's Avatar
Default RE: Gas Leak
sounds like you over filled the tank, the only time its ever happened to me is when i over fill. you know how your pumping gas and the pump stops for you and then you keep going.
Old Dec 1, 2006 | 02:45 PM
amdmaster1's Avatar
i never over fill.... and it happens to me almost every time i fill up. and its not a broken pipe cuz then i would have no gas in my tank ever.... and i'm only getting 13-15mpg is that bad or normal?
Old Dec 1, 2006 | 02:49 PM
Bad gas cap, damaged tank neck, EVAP screwed up ???
Old Dec 1, 2006 | 02:52 PM
amdmaster1's Avatar
my gas cap is new... its one of those locker gas caps... the neck might be broken i'll have to check but what would be wrong with the evap?
Old Dec 1, 2006 | 06:22 PM
MadMikeZ28's Avatar
There is a black, round evap canister under the hood with a filter in it. It may be plugged. Try to blow air through the line labeled "tank". If the neck was broke chances are it would leak behind the quarter panel.
Jelz28
Jul 18, 2012 06:01 PM
95mero
Jan 5, 2009 09:14 AM
derrickdiggler
Oct 12, 2007 01:22 AM
derrickdiggler
Sep 27, 2007 02:26 PM
daltons 1980
Sep 24, 2007 09:04 AM
