GAS GUAGE PROB.
Old Aug 10, 2005 | 06:52 PM
aaronsirocz's Avatar
Default GAS GUAGE PROB.
HEY, MY GAS GUAGE BOUNCES BACK AND FORTH WHILE DRIVING SO I NEVER KNOW HOW MUCH GAS I HAVE, DOES ANYONE KNOW IF ITS PROB THE GUAGE OR THE ACCENDING UNIT IN THE TANK. IF YOU HAVE AN IDEA LET ME KNOW THANKS. AARON
Old Aug 11, 2005 | 03:53 PM
89Maro's Avatar
Default RE: GAS GUAGE PROB.
Bunces like CrAzY or just moves up and down as you go up and down hills? I think and I might be wrong but aren't these older ones on a gravity bob or something like that??? SO depending on the motion of the fuel the gauge will alter?
Old Aug 11, 2005 | 11:50 PM
PrinceCharmmin's Avatar
it sounds like the accending unit in the tank.... the float could be messed up.
Old Aug 12, 2005 | 06:11 PM
it bounces like crazy, i priced the accending unit and its like 230 bucks, thats crazy. i just needed some extra advice b for i spent that kind of money on one.
Old Aug 13, 2005 | 02:43 AM
You may want to take a good look at all the electrical connections on the gauge circuit, just in case something is loose.
You can test the gauge itself. Disc the connection and the gage goes to full, put 12 volt across the gage terminal and it should show empty. That is if you can get to it.
You can test the sending unit with an analog voltmeter (cheap one with a dial from Radio Shack) and probe the leads to the sending unit. Start the engine and drive around & see if the voltmeter acts as crazy as the gage. If it does, and all connections are good, u got a bad sending unit.
The bad part about changing the sending unit is that it is inside of the tank and in late model Camaros there is no access to the tank. U need to take out the rear axle and drop the tank. Don't know what model u have, but in older cars they used to put an opening with cover to allow acces to the tank.
Some shops cut a hole in floor, then screw a metal plate over the hole, and cover it back up with the floor carpet, and charge labor as if they done it the right way.
Old Aug 16, 2005 | 01:15 AM
i have an 86 iroc
Old Aug 16, 2005 | 02:11 AM
Do't know for sure about the 86, but pull up the carpet behind the rear seat & see if if there is a cover plate on the floor above the tank.
Old Aug 16, 2005 | 03:13 AM
Ok thanks for the help, ill let you know what i find out.
95z28htch
Dec 30, 2009 02:18 PM
94 b4c
Mar 7, 2009 10:48 AM
lilwill
Aug 29, 2008 10:48 AM
bluovlh8er
May 16, 2007 08:51 PM
91_cam
Feb 25, 2007 04:44 PM
