fuel pump help
Old Mar 9, 2009 | 08:35 AM
Graphite07's Avatar
Default fuel pump help
okay what steps do i need to take to remove the gas tank for the dead fuel pump swap out? i know the exhaust has to come down and the heat defelctor and two cross members behind the tank is that all?
Old Mar 9, 2009 | 04:45 PM
350rs's Avatar
March 2008 ROTM
if you can take the rear out do it. its far from necessary, but it does make things easier.
Old Mar 9, 2009 | 08:43 PM
Graphite07's Avatar
so the rear end does not have to come down right? okay if so i am pulling it apart saturday,
Old Mar 9, 2009 | 11:53 PM
350rs's Avatar
March 2008 ROTM
dosent have to no. but like i said, it does make things easier. let it hang as much as you can though.
Old Mar 10, 2009 | 06:13 AM
Graphite07's Avatar
thank you. will be doing this saturday
Old Mar 16, 2009 | 11:34 AM
Graphite07's Avatar
okay got most of the car apart. befo i remove the tank i noticed there was a plug on the back side of the tank mount to body of the car what is that? it leads to nothing just mounted to the inner body panel.
Old Mar 17, 2009 | 11:13 PM
Graphite07's Avatar
okay tank is out new fuel pump is in. any advice on reinstall the tank?
Old Mar 18, 2009 | 11:11 PM
Graphite07's Avatar
i see what you mean, i had to lower it down to get the tank back in.
Old Mar 24, 2009 | 06:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
i replaced mine, but my exhaust was all welded together. i was able to remove the rear mounts, cut the hanger on the cat, and removed the rear shocks to lower the rear to get it in. found out later the wire was just loose on the battery, but oh well. its comming down again to get a high volume pump sometime this year
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
