Fuel Pump
Old Sep 3, 2012 | 12:44 PM
92ttopRS's Avatar
Default Fuel Pump
Well after 200,000 miles the original fuel pump crapped on the 92. Got my money's worth. Did it the right way and dropped the tank. It took 5 hours in the driveway by myself. Wasn't that bad. So guys do it the right way. Runs like a champ again!
Old Sep 3, 2012 | 04:46 PM
Yeah, with the 3rd gen's, dropping the tank is the way to go. On my old 91, I started out by cutting an access panel to remove the pump from above. But since these cars don't have any line disconnects, like the 4th gen's do, that would mean cutting all the steel lines, and flaring (at the very least) the supply line to retain a high pressure flare connection. Half-arsing the fuel lines is something you don't want to do, considering it's above the exhaust. I ended up dropping the tank and doing it right.
Old Sep 18, 2012 | 10:36 AM
Edwardgp's Avatar
Drop the tank it gives you a chance to check it out and paint the tank.
jon_uscg2001
Aug 25, 2011 12:23 AM
nehidustin
Jun 28, 2010 07:30 PM
carmodder
82-92 V8 Tech
Jun 23, 2008 12:50 PM
BlueKitsune
Oct 5, 2007 07:54 PM
johnson3034
May 25, 2007 09:35 PM
