fuel pressure regulator
Old Mar 5, 2007 | 06:45 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default fuel pressure regulator
alright, my car was being an *** the other day, spitting out raw fuel, black smoke, etc. i know its not ignition as it would rev freely. my mechanic told me it was the fuel pressure regulator. i got the rebuild kit, however, i cant get mine out. the passenger front bolt on the fuel rail is stripped somewhat, and my wrenches wont stay on it. is there anyway to rebuild the pressure regulator without taking it out of the engine? oh, and today it ran fine, i went up and down the road with no problems. i need to get this done asap as its my daily driver and ive missed enough school already this year because of this car
Old Mar 5, 2007 | 07:18 PM
blackz87's Avatar
Default RE: fuel pressure regulator
Before you try to work on fuel pressure regulator try replacing the fuel filter. Also for your info you will need a special torx socket with clearnace for a raised pin in the mounting bolts. A special feature by GM to prevent tampering with the regulator.
Old Mar 5, 2007 | 09:07 PM
microkid's Avatar
March 2011 ROTM
Technical User
i noticed those. if i can get one, does that mean i can rebuild it without removing it?
Old Mar 5, 2007 | 11:38 PM
blackz87's Avatar
I don't think you can. If I remember, once you remove the bolts the whole top hat l comes off as one piece. Iwould forget about fixing it, I would just by a new adjustable one.
Old Mar 6, 2007 | 09:18 PM
microkid's Avatar
March 2011 ROTM
Technical User
well, i got it all repaired, and it has a somewhat different feel to it, namely a minute amount of throttle response. there was a lot of crap on the old rubber boot that probably caused the pressure.
Old Mar 7, 2007 | 12:13 AM
blackz87's Avatar
ORIGINAL: microkid
You must have found that special torx bit??? Well a good job and did you check and reset the fuel pressure???
Old Mar 7, 2007 | 11:22 AM
microkid's Avatar
March 2011 ROTM
Technical User
yea, napa sells them. they were like a dollar for two bits. and i checked and reset everything, but i dont have a fuel pressure gauge.
Old Mar 7, 2007 | 11:36 AM
blackz87's Avatar
ORIGINAL: microkid
Another inexpensive Item, I would check into one. It hooks up to the schrader valve. Myself I installed a gage under the hood to monitor the fuel pressure mounted on the passenger side fender.
[IMG]local://upfiles/2696/81AF94D5886541F8A347F1C073600730.jpg[/IMG]
Old Mar 7, 2007 | 06:27 PM
microkid's Avatar
March 2011 ROTM
Technical User
im not that concerned with monitoring fuel pressure as of now, my engine is completely stock. however, what runners do you have, and whats the extra belt runnin to under the alternator? do you have a serp. belt for the air pump? mine was a v belt off the crank
Old Mar 7, 2007 | 06:34 PM
blackz87's Avatar
ORIGINAL: microkid
Those are SLP runners, and I will have to check on your question about the belt.
royco95
Aug 2, 2015 10:25 AM
sebi1990
Mar 6, 2011 06:58 PM
Kendagenius
Aug 13, 2010 08:34 AM
chadillac4110
Sep 17, 2009 08:43 AM
HURSTLT1
Dec 26, 2005 11:18 PM
