Engine ID
Old Jun 6, 2008 | 11:32 AM
GearJammer's Avatar
Default Engine ID
I have an 84 that used to be a V-6 173ci. Now its has a 350 4 barrel carb. I know the engine is from 1995, I just don't know what vehicle. All i can see when i open the hood is the firing order on the engine.
Side problem, none of my gauges work. I think due to the engine swap. And i believe the car computer was taken out also. So, Ive been told the only way for me to go is aftermarket gauges... correct? Plus i dont konw how the speedo will hook up to the tranny, if the tranny was meant for electronic gaugues. because wioth carborated cars i think the gauges are pressure orientaed. Please gimme any info you can and lemme know if i am way off in some areas. thanks. -mike
Old Jun 6, 2008 | 02:08 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Default RE: Engine ID
You can find the engine casting number on the driver side to the rear of the valve cover. Look in the 1st gen section, at the top is a sticky about locating numbers and stuff.
Go to the 3rd gen section for the questions about the motor and all that.
Welcome to the forums btw.
Old Jun 14, 2008 | 09:33 AM
bluovlh8er's Avatar
welcome to the forums!
onefastls1
Jan 2, 2013 01:45 PM
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
jrb78
82-92 V8 Tech
11
Dec 16, 2007 07:05 PM
