door removal on a 91 RS
Old Apr 26, 2007 | 09:53 PM
modifyd's Avatar
Default door removal on a 91 RS
another question about this camaro. how do i get the doors off the car? i see 3 bolts on the top hinge but the bottom one, do i have to take that plastic piece off by the hood release button to get to some bolts?
Old Apr 26, 2007 | 10:49 PM
MadMikeZ28's Avatar
Default RE: door removal on a 91 RS
Three bolts on each hinge. If you go through the fender it will be easier for you if you don't have special tools.
Old Apr 27, 2007 | 12:16 AM
modifyd's Avatar
go through the fender?? how do u mean., the way i see it i have to get the front bumper off then i can get the fenders off then i can get to the door hinges, am i correct? cuz i cant get the front bumper off at all. thanks for all your help.
Old Apr 27, 2007 | 12:35 AM
rollermotor's Avatar
all you should have to remove is the plastic inside the fender, then you can get to that front bolt easier, it also is easier if you get the tire out of your way, but it is not impossible to do with it there. and you have to get two bolts from the inside, so you will have to remove the kick panel, there is a screw that can be hard to find in it, (because of the carpet),if you have never done that before, it is in the middle, just probe with a scewdriver to find it.
CheVy_R0aRrR
Jun 8, 2011 01:39 AM
BasicConcepts
Jan 4, 2011 11:02 AM
Camaro95
Jul 27, 2010 08:25 PM
kats69
Sep 23, 2009 10:33 PM
RFxCamaro
Jul 7, 2008 11:00 AM
