1996 Camaro RS Door FRICKING Panel Removal
Old Jul 7, 2008 | 04:46 AM
RFxCamaro's Avatar
Default 1996 Camaro RS Door FRICKING Panel Removal
I got almost everything out but my car is a manual window so i need to remove the door crank, how the heck do i remove it ive tried evrything i can think of.
Old Jul 7, 2008 | 09:46 AM
th3po1son's Avatar
Default RE: 1996 Camaro RS Door FRICKING Panel Removal
[*]Remove the door window regulator handle and spacer, as follows:[*]Remove the handle by pushing door handle clip remover J 9886-01 between the handle and the spacer to release the clip.[*]Remove the spacer from the spindle.[/ol][/ol]
Maybe youll understand. I have power windows so I dont lol.
Old Jul 7, 2008 | 11:00 AM
importmd's Avatar
most of the time the handles are held in with a c-clip. you need to push the door panel in around the handle so you can see it, all need is a hook tool to pull the clip off.
fadedx
Feb 18, 2015 07:38 AM
thebugbox
Mar 24, 2010 10:01 PM
kats69
Sep 23, 2009 10:33 PM
Edlanta
LS Series Tech
May 31, 2006 10:41 AM
1968CamaroFl
May 30, 2006 12:29 AM
