disabling the airbag sensor?
Old Apr 8, 2008 | 06:07 PM
94CamaroSFI's Avatar
Default disabling the airbag sensor?
I was in a minor fender bender Yesterday in my 91 Rs, and I was wondering how to disable the airbag, and if there is a safety switch that needs to be reset.
Old Apr 8, 2008 | 07:00 PM
Default RE: disabling the airbag sensor?
Why do you want to do that?
Old Apr 8, 2008 | 10:04 PM
MadMikeZ28's Avatar
If you have an airbag light on and none deployed and worried about the bag popping just unplug the yellow connector at the bottom of the column and while sitting in the seat like normal put a piece of black electrical tape over the light.
The light is designed to be on if there is any problem detected. Like a wire unplugged. If the light is on after your accident but no bad deployed there is a chance that only one sensor worked and may need replacing.
Old Apr 1, 2009 | 12:42 PM
87camarospeed14's Avatar
you can unplug the wire but i find it eaisier to pull the fuse and the lite should go out
edog2
Sep 1, 2013 08:31 AM
jasong1968
Jan 9, 2012 01:41 PM
fuhhuayt
May 5, 2011 01:04 PM
irocktheIROC
Jan 4, 2010 06:37 AM
Isphius
Jan 18, 2008 12:31 PM
