ls1 maybe
Old Apr 1, 2009 | 06:26 PM
04STichris's Avatar
Default ls1 maybe
ok my budget is 4,000 dollars and my stock 305 is getting tired!!! and i really wanna upgrade to somthing thats alot more impresive any sugestions i was thinking lt1 or sumthing ?? and if i did would it be a bolt in and go witch i doubt im sure im going to have to get a ecu and all thats **** im sure but what do you guys think and thanks for the advise
Old Apr 1, 2009 | 06:40 PM
c4maro's Avatar
ur new to the forum, so heres ur warning no swearing. Welcom to camaroforums.
and you need new motor mounts to drop in a lt1
Old Apr 1, 2009 | 06:42 PM
350rs's Avatar
March 2008 ROTM
lt1 is a semi bolt in operation. Everything matches up, however the computer and harness must be replaced. LS1 ( like mentioned in the topic..?) is a big deal and will cost well over 4k to do correctly.
Old Apr 1, 2009 | 06:45 PM
04STichris's Avatar
thank you very much for this reply and sorry for the swearing!! so all i need is new motor mounts i gues i could just go hei and carbed instead of the lame tbi and its a 5speed as well
Old Apr 1, 2009 | 08:21 PM
350rs's Avatar
March 2008 ROTM
LT1 share the same engine mounts, its just a good idea to replace them while its out. And the LT1 isnt a TBI setup like you currently have. That system thats on it factory is pretty good. they do have aftermarket manifolds for it though that can flow a bit more air
