changing from mech speedo to electric.
Old Aug 31, 2006 | 04:11 PM
cdoyle's Avatar
Default changing from mech speedo to electric.
As you saw from my other post, I'm going to convert my 84 dash to a 92 style.
One of the things I need to do is convert my cable driven speedo to electric.
I got a VSS unit out of a 91 camaro, and today, I removed the old cable driven unit, and noticed that the gear on it. Is larger then the gear on the electric version.
How do I get the right gear for the electric version?
Is there a cross reference out there?
Thanks
chris.
Old Sep 2, 2006 | 05:42 PM
Default RE: changing from mech speedo to electric.
The VSS gears are all the same, the computation to display the right speed is done by the PCM. If the MPH is off, the PCM needs to be calibrated.
BLK79
Jul 26, 2012 09:26 PM
DashingDaryl
May 21, 2012 07:11 PM
osduck5
Oct 3, 2010 12:05 AM
edog2
May 11, 2010 10:05 AM
MochaCaliGirl
Feb 13, 2009 01:44 PM
