Brakes
Old Aug 23, 2006 | 02:01 AM
hsdragracer's Avatar
Default Brakes
i own a 89 camaro z28 and i have been having a problem with my brakes. ever since i got the car i have noticed a slight pull to the right under heavy braking. i have put on 1500 miles since i got the car and bleed the brakes somewhere in the middle of that time. recently the pull to the right has gotten much worse and today it was so bad that it was hard to steer under LIGHT braking, when braking i could damn near make a right hand turn the pull was so bad. after the car sat for 5hours i drove home and the car seemed normal (only pulled to right under heavy braking). any ideas of whats going on? air in the lines to opposite brake? bad pads? Once i got home i jacked up the car and both wheels didnt spin too freely, could that just be that the calipers arent releasing all the way? ANY help and ideas for fixing it would be appreciated thanks
Old Aug 23, 2006 | 10:27 AM
blackz87's Avatar
Default RE: Brakes
The rubber brake hoses are shot. If they are the originals replace with SS lines, and that should cure your problem.
Old Aug 23, 2006 | 01:14 PM
Default RE: Brakes
where would i be able to fine them? summit racing?
Old Aug 23, 2006 | 02:15 PM
Default RE: Brakes
If the hoses don't do it, then you may have a dragging caliper or a worn out front end.
Old Aug 23, 2006 | 03:10 PM
blackz87's Avatar
Default RE: Brakes
ORIGINAL: hsdragracer
Yes, that would be a good place to start. Also I know they have the SS lines.
Old Aug 24, 2006 | 11:24 PM
Default RE: Brakes
thats what i was thinking because when i jacked the car up the 2 front wheels dont spin as freely as they should. any i ideas on how to fix this or is that somehting where i need new calipers and pads?
Old Aug 25, 2006 | 03:10 AM
Bblock's Avatar
Default RE: Brakes
Do you think a dragging caliper would cause crazy brake dust to build up on the wheel. My driverside covered and the passenger side isn't. I just washed both wheels like a month ago. I don't have any major pulling when I brake.
Old Sep 1, 2006 | 05:51 PM
IROC_Z's Avatar
Default RE: Brakes
A piston could have seized up on one of your left side brakes. This happened to my Datsun 280ZX. it used to pull to the right under any kind of braking so i checked all of the brakes with a buddy of mine and found that the left rear caliper wasnt clamping down all the way.
Old Sep 2, 2006 | 01:41 PM
Default RE: Brakes
Pistons can seize and the caliper sliders (this car uses floating calipers) can rust up and prevent the calipers from centering themseves about the rotor causing the pads to drag or not apply evenly. Take the brkes apart, they won't get fixed by talking about them.
Old Sep 3, 2006 | 12:01 AM
ScottD's Avatar
Default RE: Brakes
Im gonna vote caliper as well. I had a caliper sieze up on me once, I hit the brakes and the damn thing almost pulled mo off the road.
camarodude77
Dec 16, 2015 05:52 PM
osduck5
Jun 12, 2009 08:47 PM
importmd
Mar 17, 2008 09:43 PM
92camaroRS
Jun 1, 2007 09:31 PM
coprunr
May 16, 2007 04:40 PM
