which carb?
Old May 9, 2010 | 05:15 PM
forevverlost's Avatar
Default which carb?
i have an 87 305carbed im gonna get the intake gasket replaced. should i change the intake and what is a good replacement carb. this is a dd so i dont want to kill my milage but would like something nice. any suggestions?
Old May 9, 2010 | 05:24 PM
Jr. Mechanic's Avatar
August 2009 ROTM
If it's the original computer controlled Quadrajet, keep it. Nothing aftermarket is going to perform better than that carb. If it's like most Qjets it's probably in need of a rebuild. Get a rebuild kit and a can of solvent and go at it.
For the intake, if you want to spend the coin a basic Edelbrock Performer or equivalent will suffice. You will need the spread bore version for the Qjet. If your EGR is in place keep that in mind when ordering one.
Old May 9, 2010 | 05:26 PM
ok thnx for the info. i havent done alot of mechanic work... some but not alot. is the rebuild very tedious?
Old May 9, 2010 | 05:31 PM
August 2009 ROTM
If you're just starting out, a carb rebuild might be a little difficult for you. I'd say go for it though. Books can be had for around $20 bucks to rebuild a Qjet that have detailed step by step instructions with pictures. It will still be cheaper than paying someone to do it and you'll learn something in the process.
Old May 9, 2010 | 05:49 PM
kyphur's Avatar
The Edelbrock Performer has both square bore and spread bore patterns drilled for either setup.
Old May 9, 2010 | 05:53 PM
August 2009 ROTM
Sorry, I should have worded it a little clearer. I know the Edelbrock Performer is dual drilled, I just said he needed a square bore intake if he looks at something other than a Performer.
Old May 9, 2010 | 10:14 PM
ScottD's Avatar
In my opinion, a home rebuild of a carb never comes out right. Especially not for a guy with little experience. All you can really do is change gaskets and blow out jets an passages. It never worked for me. I'd suggest he gets a rebuilt q-jet. Carbs can be real fussy.......
carguylt1
Mar 28, 2011 10:30 AM
white85camaro
Jul 29, 2010 05:16 PM
cadfleet
Jul 6, 2010 10:28 PM
albo1989
82-92 V8 Tech
Jul 1, 2010 07:40 PM
Gordon24Camaro
Jan 11, 2007 10:46 PM
