car stalled
Old Jun 18, 2010 | 07:16 PM
  #21
well im not privey to info on the third gen cars so im not real sure of the hot wire color that goes to the distributor.. its pink on the lt1 forth gens.
Old Jun 18, 2010 | 07:49 PM
  #22
3rdgenowner's Avatar
ok the security light comes on when I turn the key on! I never noticed that in the year I have been drivin it! Any way to bypass this? As I am assuming that my key is worn! Or what?
Old Jun 18, 2010 | 10:57 PM
  #23
If it was the security system, the engine wouldn't turn/crank over at all.
I used to have a 91 a couple of years ago, so hopefully I didn't forget it all!
Mine was an RS 305, and it had a separate coil, not an HEI distributor with the in-cap coil. Is that what you have?
The switched power supply wire to the coil is pink. You want to check that wire with a volt meter and see if you're getting 12 volts when the key is on. There are also three other wires on the other side of the coil that go to the distributor. They are white, black, and pink, so don't get that pink wire confused with the pink supply wire.
When you were checking for spark with a plug, you need to be sure the plug was well grounded. If you have a timing light, you can hook it up to any of the plug wires, or coil wire, and check for spark that way.
If you're getting power to the coil, but still no spark, then the two most likely culprits would be the coil or the ignition module (under the distributor cap). You could have toasted either one of those, for whatever reason, including age.
Old Jun 19, 2010 | 04:39 AM
  #24
Than you! I also have the rs 305 with separate coil which is right in frony of distributor, that is what I changed! I will check for spark with timing light and get an ignition module to day after work! I really appreciate everyone's input and help here.
Old Jun 19, 2010 | 03:43 PM
  #25
Thank you again everyone! It was the ignition control module! My car is up and running! Nice to know there are still people around willing to help out others!
SunRunner
Nov 4, 2011 08:32 PM
3rdgenowner
82-92 V8 Tech
Jun 16, 2010 08:01 PM
scatterbrained
Apr 13, 2010 11:50 AM
0235thcamaro
Feb 12, 2009 08:27 PM
