BRAKE'S ?????
Old May 11, 2007 | 11:30 AM
zachyfarms's Avatar
Default BRAKE'S ?????
Need to know how well some of your guys breaks work.. Been driving the car for few weeks never speeding and the brakes aren't great but never had to slam them to stop.. Had incident last night and at about 30 mph, and i knowin any pos on the road should have been able to stop but couldn't stop in a 50ft distance or even 80ft.. can you guys lock your breaks up if you hit hard enough? how would you rate your stoping performance. I dont have leaks anywhere and fluid is in booster.. I just cant believe the brakes on this car are that crapy.. there has to be something wrong.. just coming up to normal stops i have to get in to it pretty good to stop.
Old May 11, 2007 | 11:31 AM
zachyfarms's Avatar
Default RE: BRAKE'S ?????
its an 84 z28 305
Old May 11, 2007 | 03:15 PM
ghotachevy's Avatar
whaats your pedal feel like firm just goes to floor spongy then firm
cold have air in line your master cylinder could have take a ****
more info would help
yes if you stomp on them the fronts should come pretty close to locking up
Old May 11, 2007 | 03:25 PM
zachyfarms's Avatar
no the pedal is soft.. it actually feels like its going almost to floor.. a couple pumps helps a little but not much.. i'll bleed and and see what happens.
Old May 11, 2007 | 03:38 PM
ghotachevy's Avatar
yea do that first bleed all four start at longest line first back pass so on if that doesn't help take a look at the master cyl.
Old May 11, 2007 | 03:40 PM
ghotachevy's Avatar
also what do your pads look like could be close to gone can make pedal go soft sometimes
Old May 11, 2007 | 11:15 PM
rs305's Avatar
yea i locked mine up one time going 30-35 dry road. Good tires too so the brakes are not bad.
Old May 12, 2007 | 10:49 PM
MadMikeZ28's Avatar
Bleed the brakes. They should be firm at first. You should not have to pumpthe pedalto get them firm. If you are by yourself try to gravity bleed them. Make a trip around cracking open all the bleeders and the next trip around if there is fluid coming out close them.
Smittys_z28
Dec 24, 2014 02:14 PM
Willie Anderson
Dec 22, 2012 10:23 AM
XxCaMeLxxToSiSxX
Dec 8, 2010 11:27 PM
jp 71 camaro
Nov 7, 2010 08:36 PM
tyler2497
Mar 10, 2007 03:35 AM
