brake problem
Old 02-25-2008, 04:34 PM
MadMikeZ28's Avatar
Default RE: brake problem
You and Murphy are old friends arent you Scott.
Old 02-26-2008, 12:25 AM
age84's Avatar
March '09 ROTM
If you are going to do the brake line youself and you need to cut it down make sure you get a double flareing tool for the ends and do it right if you don't have onealready they are pertty cheap.
Old 02-26-2008, 05:00 PM
gvmv's Avatar
I second the opinion just replace the cylinder. I delayed replacing the cylinders on an oldsmobile I was driving. only half the brakes worked. Was fine until the other half went out in a parking lot with un-even levels. The 10' drop down a landscaped area from one parking area to another was not a fun ride when the rest of the breaks went out. Or the 45 min drive home with no brakes. Take it form someone who delayed fixing breaks because I was being cheap. Just fix it, fix it right and you won't have to spend any money for quite a while on brakes.
Old 07-20-2009, 05:19 PM
traumadog's Avatar
Bump for an old thread - anyone know how hard it is to replace the rear hard line? I've got that same dreaded puddle below the driver's door.
Old 07-21-2009, 12:13 AM
Stix80's Avatar
my line wasnt too bad to get out i had to get it off to take out my rear end mine wasnt rusted or anything but i sprayed with some wd40 when i first started working on pulling the rear end so it could penetrate
JPrice
06-19-2012 07:34 AM
maro28
05-19-2010 10:12 PM
nnewquist
12-17-2009 01:56 PM
Camaro_Boi69
04-11-2008 11:30 PM
camarolover91
11-19-2007 05:06 PM
Quick Reply: brake problem
