Backfiring when Step on gas and wont get any power please help
Old Dec 4, 2012 | 06:17 PM
83z28guy's Avatar
Exclamation Backfiring when Step on gas and wont get any power please help
the car wasnt backfiring when i got it but the a friend notice the distributor cap wasnt tightened down and he moved it around we got it back the right timing (as far as we know) and tightened it down and changed the spark plug wires but not the car will back fire when i press gas in neutral and in drive trying to accelerate also doesnt get very much power. what could this be, any ideas?
Old Dec 4, 2012 | 06:21 PM
RonnieJ86's Avatar
the only thing you probably could do is triple check the timing again and make sure your plug wires are in the right spots
Old Dec 4, 2012 | 07:09 PM
^^^ yep, sounds like a missplaced plug wire. or lose cap could have gotten damaged during the run.
Old Dec 4, 2012 | 07:13 PM
Oh, so you used one of those "guess" type of timing apparatuses, eh? Yeah, those are deadly accurate!!
Old Dec 4, 2012 | 10:52 PM
83z28guy's Avatar
no i used a timing light for the timing
Old Dec 5, 2012 | 07:49 AM
djs383's Avatar
The distributor cap should have nothing to do with timing...sounds as if your friend knows enough to be dangerous
Old Dec 5, 2012 | 08:36 AM
Edwardgp's Avatar
New distributor cap and plug wires in the right order should fix the problem. Let us know.
Old Dec 5, 2012 | 08:55 AM
microkid's Avatar
March 2011 ROTM
Technical User
make sure you install the jumper wire as needed to correctly set the base timing, otherwise you are just hurting yourself
Motocrossmom216
Apr 22, 2014 09:17 PM
LolVtech
Feb 17, 2014 06:08 PM
Phatbudde
Jul 27, 2012 09:44 AM
hoot79714
Oct 22, 2011 08:37 AM
1977Camaro350
Oct 16, 2010 07:39 PM
