any suggestions on increasing hp on my 88 iroc with a 350
Old Jul 23, 2006 | 04:54 PM
Withered962's Avatar
Default RE: any suggestions on increasing hp on my 88 iroc with a 350
also should i just get a brand new zz4 engine from gm or just rebuild my 350 in the iroc... it has close to 140k miles on it :X the zz4 was like under 4 grand.. yeah it's fuel injected, Looks "perdy" too
Old Jul 25, 2006 | 03:58 PM
86PREDATOR's Avatar
Cheap HP gains....
1. Lighten the car, rip off smog equipment, A/C, ditch spare tire , real fanatics pull speakers and headliners/ overhead /center consoles, back seat. You choose how light u wanna go
2.Pull honey comb out of MASS airflow sensor.
3. Make a home made ram air kit with milk jugs and aluminuim dryer pipe and a old intake snorkel off a carburated GM car. Mount the snorkel where your air dam is under the front bumper (mind you need the air damn to help cool your radiator so only cut off about a foot of it)
4. BOSCH +4 or +2 plugs, yes they really help.
5.. K & N Yes it helps
6. Ignition module, coil, and new wires.
7. Run synthetic oil if it does not leek out of your car ( good for at least 5 HP and u can leave it in for 6-8k miles).
8. Punch out the ceramic in your Cat.
7. Replace stock crossflow with cherry bomb
8. Throttle body spacer
8. Gasket match and or port TB, spacer, and intake, if you really have alot of time and skill, gasket match your intake toyou heads, and your exuast mani's/headers.
9. since u eliminated your A/C and smog pump, pull your PS pumb belt when you are sure your gunna be racing ( need to get old 86 or older non serpentine pullies, if you order new migh as well get the underdrive kit.
10. CHIP!
11. Now its gunna get spendy, and I am leaving work so im out, l8r
Old Jul 25, 2006 | 04:04 PM
blackz87's Avatar
ORIGINAL: 86PREDATOR
Cheap HP gains....
10. CHIP!
Now you can park your car in the junkyard and no one will notice it with the junkers. [sm=badidea.gif]
Old Jul 26, 2006 | 10:26 AM
86PREDATOR's Avatar
Why? its just a toy.
So what in your opinion is a bad idea, removing A/C?
Removing smog equpment?
Please read the first sentence "cheap HP gains"
Noob
MikeK02048
Sep 10, 2012 08:40 PM
mxr81999
Sep 5, 2012 02:23 PM
big greg
82-92 V8 Tech
Sep 9, 2010 07:25 PM
sicked_wick
Apr 17, 2008 09:01 PM
70camaro
Aug 15, 2007 06:22 PM
