Increasing speed a bit
Hi I got a 3.8 96 RS which obviously a V6. I'm not looking for anything thats gunna make my ride a beast of an automobile but I was just looking on increasing the speed to a respectable V6. I looked over the list of bolt on mods and didn't really know which ones worked the best in terms of increasing HP and so on. Was just seeing if anyone had any imput on what types of things I should look at buying. Thanks
Most ofthe bolt-ons are pretty close to one another in terms of performance. Rear gears would be another choice, unless of course you are one of the lucky ones with the Y87 package. There are some good cams out there as well. With those though, I'd recommend upgrading your valvetrain as well (i.e. roller rockers, valvesprings, pushrods).
thats what the stickeys at the top of the v6 section are for bud but start were everybody starts go with a cold air intake first then cat back exaughst then headers high flow cat LS1 aluminum drive shaft as stan said rear gears posi (unless you have y87) then finally the big stuff cam rollers lifters then can go with head work....or if youve got some cash to burn go with the base bolt ons first then look tword forced indcution....Ie supercharger or turbo id reomend superchargher...
ORIGINAL: 96WhiteLightnin
There isnt much you can really do to the 96 RS, i think SLP made one CAI but its $300, pretty much all you can do is cat back
300 bucks for a CAI is freaking rediculous go with one from ebay i presonally got mine from a company called chrome intakes for 76 bucks shiped when it comes to cai particually 93-97 cars its just a a tube with a better filter at the end as long as you get a good filter ie K&n as long as the tube is solid and fits together tightly a tube is a tube is a tube is a tube no real subtleys too it its just a tube....
ORIGINAL: 02StanGT
There is ALOT more than you think.
ORIGINAL: BigNic
