??? about adjusting drum brakes.
Old Aug 11, 2007 | 05:49 PM
ScottD's Avatar
Default ??? about adjusting drum brakes.
OK, lets get back to basics.....I think I need to adjust my rear brakes. Reason 1) they are starting to squeak on my first couple of stops (all new hardware, cylinders to springs) 2) MY pedal feels mushy for the first inch and Ive already bled the lines several times 3)I just wanna rule it out.
Is there any guide line or simple way to do this? Ive always in the past dont it with the wheel off and felt by hand till it started catching and then backed the adjuster off a bit. Any suggestions?
Old Aug 11, 2007 | 06:44 PM
MadMikeZ28's Avatar
Default RE: ??? about adjusting drum brakes.
adjusting with the wheel off is a fast and easy way to get them close. I do that and push on the pedal with the drum on to center the shoes inside the drum. You will see after you center them it will be loose again. Then put the wheel on and go through the adjuster hole while turning the wheel in its forward direction. Once you feel you have it close push on the brake to center the shoes again and see how the drag feels.
Old Aug 11, 2007 | 07:09 PM
ScottD's Avatar
Ive never done the 'push the pedal to center the pads' thing. Ill try that tomorrow. Thanks Mike.
camarodude77
Dec 16, 2015 05:52 PM
Raidenvaga
Apr 28, 2007 06:21 PM
74_camaro
Mar 25, 2007 02:18 AM
69camaro1
Oct 23, 2006 10:59 PM
