92 RS doesnt want to fire over
Have you checked to see if you are getting a good spark. Unless way off, a retarded spark won't prevent the car from starting. Check the plugs for fouling, all that cranking and no start will soak them with gasoline, and keep the car from starting even if you fixed the initial problem.
