84 camaro in need of alternator
Old Dec 30, 2009 | 08:36 PM
bizarre660's Avatar
Default 84 camaro in need of alternator
hey all, my alternator is kinda burnt up and i am in the market for a new one. what is a really good kind? what is the type of amperage and what not i should be looking for? thanks in advance all.
Old Dec 30, 2009 | 09:56 PM
ScottD's Avatar
Kinda burned up?
Without being a wiseass, this is a real easy, off the shelf, Autozone item. I assume you are running all stock, a plain stock alternator will work. Its a 30 minute swap job. Let us know if we can walk you thru the process.
Old Dec 30, 2009 | 10:03 PM
mtn_maro's Avatar
i got it down to 10 minutes lol but in all seriousness i agree with scott go to autozone and get a stock replacement. they put out 105 amps which i would think is plenty for most applications.
Old Dec 31, 2009 | 06:51 AM
bizarre660's Avatar
Do you work in auto zone? Can you change it for me?
Old Dec 31, 2009 | 07:47 PM
mtn_maro's Avatar
no i do not work in autozone. if you wanna drive up to big bear california then i can do it for you for 10 bucks lol. but it probably is not worth it.
Old Jan 1, 2010 | 08:59 AM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
I agree. Mostly any off the shelf alternator would be sufficient. its easy if you posses basic mechanical skills..while your there why not pick up a Haynes manual and learn how to do it yourself?
Old Jan 1, 2010 | 09:10 AM
ScottD's Avatar
Bizarrae, I STRONGLY suggest you either start working on your mechanical skills or get another car. A 20 year old Camaro likes to eat little things like shocks, fuel pumps and brake lines....you need to know how to do this stuff or you wont be able to afford this car. An alternator is a great starting point to learn. There isnt much to screw up, its easy to get to and simple to swap out. Just be sure and disconnect the battery!
Old Jan 6, 2010 | 12:38 PM
MegametedK's Avatar
See if you can find one with a lifetime warranty.
Trust me it will be well worth it.
Over the years I've got 2 new ones from that wonderful little receipt.
Old Jan 6, 2010 | 04:27 PM
blackz87's Avatar
Buy 105 amp one for 3rd gen V-8. Just make sure you don't buy a rebuilt one, even if it has warranty.
cam69
Jun 3, 2015 10:44 PM
naut
Apr 19, 2013 04:48 PM
1995Camaro
Sep 14, 2010 01:28 PM
jlala
Oct 21, 2009 06:36 PM
69Pacer
67-69 V8 Tech
Oct 29, 2008 10:48 PM
