1992 350 small block first car
Old Jun 11, 2009 | 08:01 AM
djs383's Avatar
Yep, i'd agree. Check that VIN and figure out exactly what you've got the "8" would be a 350TPI, I think "F" is the 305TPI. Like camaro69 said TH350 is not stock. I think the seller is either misinformed, or is misleading. My bet is that its a 305TPI all stock with the 4L60E trans (same as 700R4). Also, like camaro69 said, the oil pressure looked like it was 20ish PSI. If you go look at it, start it, sometimes the gauges do funny things when they're keyed off.
Now, it would seem like a good project car if the body is in good shape. If it were for a daily driver or to have an original car...then maybe not. But for $1700 if the body/rear/other misc stuff is good, then it might not be that bad.
Old Jun 11, 2009 | 11:13 AM
1990CamaroRS's Avatar
Fancy Sparkle
it's an RS, look at the body kit. there's a small scoop on the front ground effects in front of the tire.
same scoop that's on that car
snopro_16
67-69 V8 Tech
14
Aug 23, 2022 04:08 PM
decaen
Feb 16, 2012 01:08 AM
gadmhahn
Oct 9, 2009 09:20 PM
acarius
Apr 7, 2009 05:53 PM
Carinhas
67-69 V8 Tech
13
Aug 23, 2007 05:02 PM
