Wanting to add rear wheel disk brakes
Hi guys just hoping somebody out there has replaced their rear drum brakes with disk and what they would suggest. Currently the rear left brake is grabbing a bit and I'm in the middle of a restoration and will be replacing the master cylinder and all parts associated. I thought now would be a good time to change the rear brakes to disk as I don't know if a certain Master cylinder would work better on four wheel disk. I am planning on keeping the 15" stock turbine wheels. Thanks for any help and suggestions
