drum to disk brakes
i have disk in the front already and i have drum in the rear but i want to turn them into disk. how much of a pain would that be? and what would be the essentials to get for that?
Buy the kit....Below is one link
http://classicindustries.com/pdf/c06...on-rearend.pdf page 637
There are several others...
Also do a web search you will find plenty on the subject.
Greg
Greg
the main things would be a better master and booster, new proportioning valveand then pulling your rear axles to put on the new backing plates. after that it is just a little more work than a regular brake job
