Drum to Disk conversion
Old Jul 8, 2012 | 10:32 AM
jumpcannon's Avatar
Default Drum to Disk conversion
ok....converting my 4wheel power drum setup to a 4 wheel wilwood disk brake setup. question....will the original master cylinder work fine? Or do i need to change out my master cylinder. I guess i will know when i hit the brakes...but just curious if anyone has a suggestion.
Old Jul 8, 2012 | 12:00 PM
If you find that you need to apply too much pressure on the pedal to stop the car, you may want to consider a master cylinder with a smaller piston diameter.
Old Jul 9, 2012 | 05:34 AM
jumpcannon's Avatar
Ok...thanks!
dmoneey05
Jul 14, 2012 05:58 PM
69 Conv
Sep 3, 2011 10:23 AM
heronlee3
Mar 4, 2008 07:24 PM
74_camaro
Mar 25, 2007 02:18 AM
69camaro1
Oct 23, 2006 10:59 PM
