Drum to Disk conversion
ok....converting my 4wheel power drum setup to a 4 wheel wilwood disk brake setup. question....will the original master cylinder work fine? Or do i need to change out my master cylinder. I guess i will know when i hit the brakes...but just curious if anyone has a suggestion.
If you find that you need to apply too much pressure on the pedal to stop the car, you may want to consider a master cylinder with a smaller piston diameter.
Ok...thanks!
