Stuttering while accelerating, NEED SOME ADVICE >>>
Old Jun 21, 2012 | 09:07 PM
TruSiaki's Avatar
Unhappy Stuttering while accelerating, NEED SOME ADVICE >>>
Okay, my '79 just started doing this yesterday. It's like it is stuttering when i accelerate. I really dont know how to describe it, but it feels like the car loses power for a split second when I accelerate. This is the first time this has ever happened, and i dont know what it could be...
MAYBE the negative battery cable is just loose? ANY SUGGESTIONS?
Old Jun 30, 2012 | 10:12 AM
Start with the basics. You need to go through the whole tuneup check before jumping to any conclusion as to what it is. Pull the cap and rotor to check, then the plugs. If anything looks bad replace it, and if it's a ugly plug replace them all.
I none of the ignition looks bad, then you will have to dig into the carb to see if it's time or a rebuild there.
Always start with the simple, cheap, easy stuff, then work towards the harder/more expensive things.
Old Jun 30, 2012 | 10:21 PM
TruSiaki's Avatar
Fixed it, the negative cable was loose, got it fixed
Old Jun 30, 2012 | 10:42 PM
Sounds like an easy fix.
iLL95
Oct 25, 2011 03:45 PM
DrQuincy
Oct 10, 2011 06:53 PM
3800camaro
Jan 31, 2011 05:44 PM
CamaroTeen
Jul 28, 2009 02:22 AM
brassknukl
82-92 V8 Tech
Aug 7, 2007 05:16 PM
