modernizing the 1979 z28 help help
Old Dec 27, 2010 | 10:24 PM
steveiselvis's Avatar
Default modernizing the 1979 z28 help help
father and son project and I need some advice. I redid the 350 great..went with a 700r4. if i stay with factory gauges how will speedo work? car has 17 inch wheels and 410 gears. would like know about custom gauges..will they work with fActoryplug ins? IM really bad with wiring so splicing might drive me nutts. is it possible to have factory speedo work with 700r4 and different gears and make it work. we want car to be like stock except with the fancy wheels and 700r4...also have a 1980 z flapper hood on it any way to make it open when i nail it?
Old Dec 28, 2010 | 01:41 AM
james hellsing's Avatar
The speedomiter should work fine, what you'll need to do to have an accurate speedomiter is change the speedomiter driven gear in the tail housing of the transmission for your new higher gears and bigger tire size, http://www.transmissioncenter.net/sp...n_______va.htm
this site tells you just about all you should need for the gear stuff.
Old Dec 28, 2010 | 06:18 AM
firebird56265's Avatar
as far as the custom gages you might look into dakota digitol(spelling) it's earley. I have heard good things about them
Old Jan 9, 2011 | 05:09 PM
Gen2-454's Avatar
Dakota digital gauges are great, and im looking into the Recaro seats also.
Disc brakes all the way around lol
NavyK9
Jul 8, 2012 10:31 PM
jazzdunn
Dec 7, 2010 11:42 PM
5861979z28
Apr 24, 2009 06:18 PM
littljohn
82-92 V8 Tech
Sep 18, 2006 09:22 PM
