Engine cranks but does not start
#22
What in the heck was a rock doing in the line?
There's gotta be a good punch-line here...I'll work on it!
#25
like a rock. lol. woh from one extreem to the other. stuck float valve maybe. hit it with a rock. or the plastic end of a screwdriver.
#27
The carb is probably not used to dealing with the pressure since it didn't have much, and now the Float Bowl-der is overflowing.
Try to ROCK the car up and down to jostle the float. The float should sink like a STONE when the gas level drops, then the needle and seat should seal with the float in the up position.
If it doesn't stop overflowing, then I'd say a carb rebuild would be in order.
#28
cleaned the carb and rebuilt it. no more gas is overflowing out of it. but now the car killed my battery and the other battery cranks the car for about a second then all you hear is the starter clicking.
#30
turns out the battery ground was shot, even though i replaced 3 days ago. she turns over but instead of turning on the carb is catching on fire. today im going to put on a Holley four barrel 4150 carb.
