Engine cranks but does not start
It now sparks but it won't start because the timing is slightly off and it is backfiring out of the carb, and shooting flames.
How do i solve this?
I have a standard distibutor with the coil that sits on top of the distributor cap, and i have a 4 barrel quadrajet.
Not sure if this will help, just click on the pic and it will enlarge.
http://www.nastyz28.com/camaro/wire/78w-eng.jpg
me and my friend have tried turning the distributor multiple times both ways, the plugs are in right,just checked them. So now i am going to rebuild the carb see if something is clogged or stuck and clean out the fuel lines.
#20
^ That's what craby was hinting at. The distributor may have been put in at tdc #1, but not on the compression stroke.
It's quite possible that it's out 180 degrees.
How to find tdc #1 cylinder compression stroke, & wiring sequence: http://www.youtube.com/watch?v=3ixfD...eature=related
How to install the distributor: http://www.youtube.com/watch?v=YdIGZ...eature=related
