Engine cranks but does not start
Old Jun 1, 2010 | 05:02 PM
So you don't have battery power going to the coil/distributor?
Can you post a picture so we know what type of ignition we're looking at?
Old Jun 2, 2010 | 12:46 AM
78camarodude350's Avatar
It now sparks but it won't start because the timing is slightly off and it is backfiring out of the carb, and shooting flames.
How do i solve this?
I have a standard distibutor with the coil that sits on top of the distributor cap, and i have a 4 barrel quadrajet.
Old Jun 2, 2010 | 07:06 AM
80ZJoe's Avatar
July 2010 ROTM
Not sure if this will help, just click on the pic and it will enlarge.
http://www.nastyz28.com/camaro/wire/78w-eng.jpg
Old Jun 2, 2010 | 11:00 AM
While someone else is trying to start the engine, turn the distributor counter-clockwise to advance the timing and see if it will start. If that makes it worse, try turning the distributor clockwise. You can do it yourself by turning the distributor a little and trying to start again, but it takes longer. It sounds like you're close, just not quite in the right spot.
Old Jun 2, 2010 | 11:29 AM
and check your plug wires to make sure you have them going to the right places.
Old Jun 2, 2010 | 08:43 PM
80ZJoe's Avatar
July 2010 ROTM
Just in case
Old Jun 2, 2010 | 09:15 PM
me and my friend have tried turning the distributor multiple times both ways, the plugs are in right,just checked them. So now i am going to rebuild the carb see if something is clogged or stuck and clean out the fuel lines.
Old Jun 2, 2010 | 09:58 PM
did you by chance take the distributor out?
Old Jun 3, 2010 | 08:38 AM
80ZJoe's Avatar
July 2010 ROTM
if you did maybe you didn't get top dead centre when you put it back on?
Old Jun 3, 2010 | 09:59 AM
  #20
^ That's what craby was hinting at. The distributor may have been put in at tdc #1, but not on the compression stroke.
It's quite possible that it's out 180 degrees.
How to find tdc #1 cylinder compression stroke, & wiring sequence: http://www.youtube.com/watch?v=3ixfD...eature=related
How to install the distributor: http://www.youtube.com/watch?v=YdIGZ...eature=related
