compression check
Old Mar 5, 2008 | 06:22 PM
73camaroSS's Avatar
Default compression check
my car 350 with a 350 th, rebuilt about 15yrs ago, fuilee heads, Z28 intake mainifold,quadrejet carb 4b,
i need to know what my compression should be and how do i do it.
[/align]
Old Apr 7, 2008 | 10:08 PM
jman511115's Avatar
Default RE: compression check
1. Get a compression check kit, like this
2. Remove all spark plugs
3. Screw the fitting into a spark plug hole
4. Have a helper crank the engine 3-4 times
5. Write down highest reading
6. Repeat for each cylinder
7. Profit
Your readings should be consistant with each other,a "bad" reading would be one cylinder 30-40 psi lower than the rest.
Look for an average of between 120-160 psi. It varies with the engine.
RFxCamaro
Sep 13, 2011 08:23 PM
MS69 YENKO/4-SPEED
Mar 27, 2010 09:53 PM
dmacqrazi
Oct 14, 2006 09:41 PM
DUBS
Sep 25, 2006 10:33 PM
