1979 Speedometer does not work
Old Jul 11, 2012 | 10:03 AM
NavyK9's Avatar
Default 1979 Speedometer does not work
Just bought a 1979 Sport coupe. Speedometer doesnt work. Vehicle runs fine, tach works, but speedometer, does not. Where would I start on this
Mechanical background = Zero (minus motorcycles). But willing to learn and open, and learning Youtube quickly.
Old Jul 11, 2012 | 11:31 AM
Disconnect the cable from the trans and swing it out to the side. Spin the cable with your fingers and watch the speedo to see if it moves a tiny bit. If it does the cable and speedo are fine, and it's the gear in the tail housing. If it doesn't move you can put a drill on the end of the cable and spin it clockwise a bit faster to see if it starts moving then.
If it doesn't move you have to pull the cable from the back of the speedo and check it to see if it's broken internally. Then replace if needed.
Old Jul 12, 2012 | 07:26 AM
NavyK9's Avatar
Awesome. Thank you. I'm excited this will be first fix on the car . I will do that today.
NavyK9
Jul 8, 2012 10:31 PM
Navigator038
Jan 27, 2011 01:31 PM
jazzdunn
Dec 7, 2010 11:42 PM
5861979z28
Apr 24, 2009 06:18 PM
littljohn
82-92 V8 Tech
Sep 18, 2006 09:22 PM
