Idling at 500RPM with A/C On... HELP!!!
Old Jul 13, 2012 | 01:01 PM
TruSiaki's Avatar
Exclamation Idling at 500RPM with A/C On... HELP!!!
Okay ill make this quick and simple.
I just got my ac system fixed and i have a new A6 compressor installed, and when i have the AC turned on, the car idles at 500RPM.
How do i get the car to idle higher with the AC on?
(P.S. With the AC off, it idles at 1000RPM, how can make the car idle higher?)
Old Jul 13, 2012 | 03:40 PM
You should have a step-up solenoid on the carburetor, that gets activated and pushes on the linkage when the A/C is turned on, which speeds up the idle. You might have: a missing, broken, or unplugged solenoid, a broken wire/bad electrical connection, or the solenoid just isn't being activated by the A/C.
fasttony350
Sep 6, 2013 06:42 PM
elieser200
Feb 16, 2012 02:17 PM
numskull223
Sep 25, 2011 10:07 PM
joeg1388
82-92 V8 Tech
Feb 28, 2010 03:49 PM
Jmoss13
Jan 31, 2010 12:26 PM
