Idling problem?
Old Feb 7, 2010 | 04:23 PM
joeg1388's Avatar
Default Idling problem?
I have a 89 Iroc with a 305 in it and a 5spd and the idle is irregular. Is that normal or could the previous owner have put an after market cam in it?
Old Feb 7, 2010 | 04:44 PM
Could be. If the idle is like a wumpity-wumpity, then that could be a cam. If the idle speeds up the rpm's, then slows down and keeps doing that, then it's something else causing that.
Old Feb 7, 2010 | 04:53 PM
joeg1388's Avatar
The rpms jump around from around 1100 to 1500. Also, when I slow down, the car shakes unless I keep it in neutral.
Old Feb 7, 2010 | 05:52 PM
Has it ever had a tune-up? If not, replace the plugs, wires, cap & rotor. No guarantees, but your engine may just thank you for that. My old 91 (305 TBI) had an erratic idle when I first got it. So I replaced all those ignition parts. I was curious which was causing the bad idle, so I tested the engine after replacing each thing. It was the cap & rotor causing the bad idle on mine.
Old Feb 28, 2010 | 03:49 PM
joeg1388's Avatar
thank you for your advice. i changed what you said to change and the car runs good now.
chuckles
Nov 9, 2012 05:04 PM
NightRider
Dec 6, 2010 03:26 PM
67-Maro
Sep 20, 2010 10:52 PM
mike83camaroBA
82-92 V8 Tech
Sep 1, 2008 12:26 PM
