Torque converter 79 camaro
Old Mar 6, 2012 | 06:53 PM
justinw23453's Avatar
Default Torque converter 79 camaro
I am hearing a rattling and I think i have had it pinpointed to the transmission, the rattling only happens in drive and reverse. I believe the torque converter bolts are loose. If someone could please tell me where the torque converter is in a TH 350 i would appreciate it.
Old Mar 6, 2012 | 08:05 PM
z28tallcan's Avatar
get under the car and where your tansmission meets your engine there is a thin metal plate (cover for the tourque conv.) most likely held on with 4 3/8 bolts. remove the cover and your tourque conv. is right there. you will only be able to see the bottom half, so if the bolts are loose you have to tourque one, turn the conveter until you see another bolt and do the same. there should be 3-4 bolts on it.
wildcat123
Jul 16, 2012 05:06 PM
tscw96
Dec 27, 2011 09:54 AM
chevypowerZ28
70-81 V8 Tech
Jul 11, 2011 12:07 PM
Bwalker
70-81 V8 Tech
Oct 21, 2009 05:40 PM
burninrubber11
Jun 27, 2007 02:35 PM
