torque converter on '85 RS
Old Dec 25, 2011 | 08:59 PM
tscw96's Avatar
Default torque converter on '85 RS
I'm looking at an 85 rs with a 305 and it says it runs good but needs torque converter. All i really know is that a torque converter is part of the transmission? What exactley is it, how much is a new one, and how hard is it to install? The car listed as $850 OBO by the way. Thanks for any help.
Old Dec 26, 2011 | 04:25 PM
blackz87's Avatar
Needs a torque converter could mean the transmission is shot.
Old Dec 26, 2011 | 04:36 PM
djs383's Avatar
True...most people out there selling cars for 850$ aren't the best at TC diagnostics. I would know mine is shot only because I know how it worked when new....I agree with Black...probobly more than just the TC. Its not hard to replace, just very time consuming as you are removing the trans and TC from the flexplate, which is tough.
Old Dec 27, 2011 | 09:54 AM
ScottD's Avatar
Black and DJS are right on. Assume you will need a transmission also. Replacing a torque converter isnt for the beginner. You have to get under the car and remove the entire transmission. The torque converter is between the engine and the transmission. Unless you have access to a lift, or are real comfortable working under jackstands (real tall jackstands) this may be a big project for you to take on. If you can get the parts cheap enough and have the area to work on the car, make sure you at least have a buddy to help manhandle the transmission. Good luck.
jrgearhead
Jan 24, 2012 01:25 AM
DeathProof
Jul 29, 2011 03:55 PM
freaky
Mar 13, 2010 12:28 PM
samtron
May 15, 2009 09:07 AM
microkid
Jan 15, 2007 06:25 PM
