stiff clutch
Old Mar 29, 2018 | 02:16 PM
GHarris5's Avatar
Default stiff clutch
I just bought a 1974 Z28 LT. The person I bought it from did a good job of installing a Tremec 5 speed and used a hydraulic clutch/throw out bearing. The problem is the peddle pressure is pretty high.It is a PITA to drive in traffic.This is my first hydraulic clutch so I don't know if this is typical, or I just have a high performance pressure plate. It operates normally, very smooth engagement and no noise or vibration. I was told I may have the wrong master cylinder, but if that was the case I would assume the peddle return pressure would be less since the problem would be charging the slave. Again, I assume releasing the clutch would not force the peddle back as hard. Can anyone confirm one way or the other if the hydraulic clutch could have a problem, as opposed to it just being a strong pressure plate.
I have to take it apart in either case, but I want to have the right parts ready to install so I can get back on the road.
Thanks
Old Mar 29, 2018 | 07:29 PM
Y2K's Avatar
Y2K
Well I duuno but I can tell you that my '01 SS has a pretty damn stiff clutch too. I had an LS7 Corvette clutch installed with many other mods including a Tick Performance adjustable master cylinder and aluminum flywheel.
It was really stiff at first but after a couple thousand miles it has lightened up a bit and is more driveable. I have a pretty lumpy cam so that doesn't help much either, she's not a daily and doesn't see much city driving fortunately since I live in a rural area. Maybe you just need some more break in miles like mine did. Do you know what clutch was used?
Old Mar 30, 2018 | 08:29 AM
GHarris5's Avatar
Unfortunately no, although the previous owner gave me his receipts, the details on the clutch and pressure plate are not there. He put a lot of expensive high performance parts in the car, so I am thinking he didn't skimp on the pressure plate. Frankly I am more worried that the throwout bearing is the wrong application.The car was originally an automatic, so there is no z bar to go back to. Since he builds a lot of cars I'm afraid this may have been the dumping ground for leftover parts from other builds.
auto
Nov 7, 2009 09:50 AM
locotrician
May 16, 2009 11:18 PM
bluegreenta
Dec 21, 2008 09:24 PM
Rise65
Nov 8, 2007 10:58 PM
Pro_built7
Apr 10, 2007 02:07 AM
